0 members (), 79 guests, and 1 robot.
Topics128,049
Posts1,055,740
#1175672 07/27/2016 6:36 PM
Can I swap bell housing with out removing clutch and flywheel?
Paul
It's a 1952 pickup.the engine I have for it has a 54 bell housing on the 235 and I need to switch to one for the 52 frame
Paul
You must remove it because it has two bolts behind the flywheel. I made this swap on my '50 and the reduction in vibration is very noticeable. You will need to ream the mounting holes about 1/8" it is a close fit, easy swap.
https://www.flickr.com/photos/advance-design_parts_co/8129099972/in/album-72157631867396207/
