| | | Forums66 Topics128,090 Posts1,056,024 Members48,432 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | I've changed my plans on swapping my converted 49 torque tube to the later model 69 rear end. I will use the 49' and cut out the old spring perches and replace with new spring perches with two holes in them. That way the emergency brakes and ect. will still work. I will clean up the 3:73:1 rear gears and swap them out. Should help on the gas mileage also. Just thought I'd let everyone know. I'll try, I say try, to get some picture of the conversion. Take care everyone. Steven | | | | | Joined: Feb 2004 Posts: 29,787 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,787 | The gears won't swap between those rear axles- - - -totally different bolt sizes, bearings, and bolt spacing. The only gear ratio upgrade available is a replacement gearset in 3.55:1 ratio that's sold by a couple of antique parts vendors. Jerry
| | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | Thanks Jerry, I didn't know that. Looks like I'll keep the 3:90:1 gears. They are fine. At least I'll have the housing done right this time. Take care my friend and thanks again.
