I have a 56,3200,235. I would like a picture,diagram,of the fuel line routing from the tank to the right frame. A short flex hose w/fittings comes out of the tank(just below the tank)to a line that goes to the frame line(and to fuel pump)How do these two lines go together? I took them apart several years ago and can not figure out how to put them together. The angles don't line up . Any help is great,Thanks Joe PS I will be off line a few hours so wont be responding immediately.I have the GM factory OEM shop manual and could not find help there.
