4 members (Rich'sToys, dt235sd, GMJim, 2-Ton), 145 guests, and 4 robots.
Topics128,167
Posts1,057,017
Members48,458
Big Bolt Forum Co-moderator
hello,
I have a tractor that I bought some re-pop lights for. They appear to have a cad plating on them. I want to prime with PPG FP50LV primer. Do I have to scuff up the surface first?
1948 Chevy 2-Ton
Scuffing isn't necessary unless it has been polished.
Paint has two types of adhesion chemical and mechanical. Chemical is the only one that is significantly influenced by the material you.spray it on. Scuffing the surface provides grooves to help the paint hold and not flake. It may have good enough adhesion without scuffing but for the price of paint I would quickly run over it with some 320
