| | | Forums66 Topics128,154 Posts1,057,015 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2004 Posts: 338 'Bolter | | 'Bolter Joined: Nov 2004 Posts: 338 | Has anyone used Jim Carter's paint?
I'd like to see some samples if anyone has a some they could put on a piece of paper and send me.
I'm thinking of the Armour Yellow, Boatwsain Blue, or Export Blue.
Let me know if you recommed another source for original color. I haven't been able to find the Bordeaux Maroon.
I'm working on a 1940 1/4 ton. | | | | | Joined: Aug 2004 Posts: 13 Junior Member | | Junior Member Joined: Aug 2004 Posts: 13 | I've bought lots of parts, new & used, from Jim Carter and had no problem. However, I bought steering wheel paint from them which was not the right color and they would not refund. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | InMy40s,
Jim Carter's gave me incorrect information on reducer to use when spraying their engine paint. I think it is a bad idea to use finish paints when you have no idea the name of the paint system (all the products your use should be chosen to work together).
PPG should be able to help you. Do you have a PPG supplier nearby? Enven if you do, the local store might not want to track down codes for old colors. TYou might want to try calling PPG directly to obtain the codes for your local supplier.
440-572-6100 PPG Color Library - had all codes 440-572-6111 PPG Tech Services Refinish (gave me the number for the Color Library)
440-572-6871 FAX number for the PPG Color Library
The above numbers are 6-7 years old. If you try any of the numbers, would you please post if they are still good?
Tim | | |
