1 members (JW51), 96 guests, and 0 robots.
Topics128,050
Posts1,055,643
#1174987 07/22/2016 5:32 AM
Hi,
I have seen an article from the BC Diesel portal,(https://www.bcdiesel.ca/en/light-medium-duty-diesel-particulate-filter-cleaning-dpf-cleaning)
Diesel Particulate Filter cleaning for light and medium duty diesel. It was new for me. I have seen DPF cleaning for the heavy duty diesel, unaware of this current trend. I am happy to hear about it. How could it function? How it improves the performance? I would like to hear from you guys.
You have a choice when your DPF is clogged. Buy a new one, or pay to have it cleaned. They are the diesel version of the catalytic converter except that they are more prone to clogging up.
A shop by me just set up the necessary equipment to perform the cleaning procedure. It has a kiln and a 120 CFM rotary air compressor, neither of which are inexpensive. They can still clean yours for less than what a new DPF costs and I believe that you can have them cleaned a number of times.
Cleaning DPF is hit and miss. If it's ash fouled or clogged from using the wrong oil cleaning is less likely to succeed. Low ash oil is critical to DPF life. Even when things work perfect DPF life is limited.
Clogging from excessive soot and the engine management fails to get into regen mode will driving or forced regen in the stall witha scan tool fails......then off car/ truck cleaning has a better chance of success. On car DPF regen normally runs about 500-1000 miles with injection of rich mixture to burn the soot off.
Some manufacture are doing better at diesels than others but EPA is making it tougher.
Add the extra cost of the diesel option, fuel cost over gasoline especially in winter makes the economics a problem.
Diesel are dying a slow death due excessive emissions problems with DPF and EGR problems and then the dreaded DEF ( diesel exhaust fluid) which has been a night mare for most manufactures. That's the system VW "forgot to install" and got caught.
DPF can cost $1000 to $3500. Some manufactures are offering factory reman.
DEF bottle, heater, pump, sensor $2000
EGR, EGR cooler, temp sensor, $900-$1500
EGR swirl valve with intake manifolds $4000-$7000
There are really good reasons Honda, Toyota and Mazda decided a few years back NOT to offer diesels in the US market.
Someone explain def to me?I don't understand fluid in the exhaust.
Tommy
59 apache 1/2t
261 short stepside
Thank you, everyone.
I work for Kenworth, What do you want to know about DPF's and FSX's cleaning machines?
