4 members (joe apple, 55shaker, Bill Hanlon, 1 invisible), 33 guests, and 3 robots.
Topics128,037
Posts1,055,463
Members48,422
#1175003 07/22/2016 1:01 PM
I put a new distributor in my truck last nite and set the points at .016. When it was running the dwell shows 24 deg. I think the spec is 32 deg. Should I close or open the gap to get this. Or just go with .016.
59chevy36 #1175013 07/22/2016 2:25 PM
I personally think you are right on. Just drive it. drive
59chevy36 #1175025 07/22/2016 4:31 PM
I pretty much believe in what instruments tell me so the dwell is low. If you are going to just do light cruising your fine but if you are going to be raising the rpm up then you're not going to get enough coil saturation time for a consistent spark. A bit surprised it's a new unit as low dwell with a feeler gauge setting is often from a worn cam or shaft/bushings. As Martin said, try it and if you get high speed flutter you will know the problem.
Evan
59chevy36 #1175031 07/22/2016 5:20 PM
Close up the gap just a little. "Dwell" indicates the number of degrees of distributor rotation the points "dwell together"- - - -points closed, to make it simple. A 6-lobe distributor cam has 60 degrees between high spots, and the points need to stay closed approximately 2/3 of the time, so 40 degrees would be the maximum points closed time. Early stovebolt distributors ran 37-38 or more, while later models dropped the dwell down to the low 30's for some reason.
59chevy36 #1175036 07/22/2016 5:56 PM
Thanks, I will close it up this eve and hope to make a speed run in the morn. I wondered about point bounce but don't think this engine will turn enough to get it.
Hotrod Lincoln #1175040 07/22/2016 7:06 PM
Think the change was the cam profile changed as per DEVE HEI upgrade how to ID early from late distributors.
http://devestechnet.com/Home/HEIgnition
59chevy36 #1175046 07/22/2016 10:33 PM
I got it to 31 deg now and am going to road test later(weather permiting) Thanks for all the help
59chevy36 #1175054 07/22/2016 11:28 PM
I believe you'll find the dwell reduction actually happened with the conversion to 12 volts. The higher voltage allowed for better coil magnetic saturation and more "points open" time for point cooling. No sense going off on some theoretical flight of fantasy when there's a logical explanation for something.
59chevy36 #1175063 07/23/2016 12:29 AM
Sir Searchalot
Sir Searchalot
Sometimes a feeler gauge is not held flat and will cause a larger gap than you think it is. As Jerry said smaller gap= larger dwell. Go by what meter says. That's why Chevy had the window on the dizzys. I love that for setting points to a meter.
Also I assume you have new points. New points MUST be examined and tweaked so that the contact pads are concentric and flat to each other. You do this by "bending/twisting" the fixed contact side of the points. NOT the lever side. Many points are cheaply made and, if not aligned, (calibrated) will be hard to set and give bad performance. The flat spring must also be spot on, not too strong, not too weak.
Bottom line is ALWAYS, how does she start and how does she run? Don't mess with mother nature.
