Sand blasting doesn't seem to get into the tight places. I'm really concerned that my expensive, not to mention knuckle-bleeding frame-up restoration will begin to bubble after only a couple of years unless I get all the rust. Is there 'anything' I can do, spray, etc. to go after those cracks after the blasting? All sheet metal will be primed with DP 90.
Thanks ahead of time.
