4 members (Ridgeback, fonz8261, SNOYL, Oswald), 207 guests, and 2 robots.
Topics128,087
Posts1,056,115
Members48,435
Sand blasting doesn't seem to get into the tight places. I'm really concerned that my expensive, not to mention knuckle-bleeding frame-up restoration will begin to bubble after only a couple of years unless I get all the rust. Is there 'anything' I can do, spray, etc. to go after those cracks after the blasting? All sheet metal will be primed with DP 90.
Thanks ahead of time.
Unless you park it in your living room, I'll put my money on the rust - it always wins. Metalprep will get into the joints, but needs to be rinsed and dried thoroughly. Zerorust suggests pouring their primer over seams and letting flow into the joint.
Now if you want to spend some $$
http://www.musclecarrestorations.com/ecoat.html
http://www.redi-coat.com/index.html
Picklex 20 is an excellent metal prep/rust converter that does not require rinsing before application of epoxy primer.
http://www.autobodystore.com/r-o-n.htm
I considered the dipping route, but couldn't find a place in over-regulated California. The parts are now in the confident hands of Ricardo Lopez (Customs by Lopez) in L.A. Again, my only real concern is what still lurks after the blasting. The Picklex 20 product does interest me and I wouldn't think thaty Ricardo would be offended if he sprayed this chemical into the cracks before applting the DP 20. But does it "really" work?
-jeff
Junior Member
Junior Member
How about "Por-15" ? Let it run in the seams or cracks. It's a mess but a good product I believe. Bill
