| | | Forums66 Topics128,049 Posts1,055,548 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 100 Member | | Member Joined: Sep 2001 Posts: 100 | I need a set of drop-down hinges for the glove box lid on my '49 GMC 1/2T PU. GM changed both the glove box design and the hinges in '49. That's ok. The dash isn't original anyway. It's a mystery replacement from somewhere between 1947 and 1953. Figuring I had a 50-50 chance, I bought a new glove box for an early '49. The screw holes match up but it's tight. The last corner won't fit over the dash metal. So, is size the only difference between the boxes or do I have the right one, and a later model box won't even match up? If the box is right but tight, does anyone recommend moistening the cardboard to slide it on?
Never start vast projects with half vast ideas.
