5 members (55shaker, Charles in CA, JW51, Southerntruck, Gray_Ghost), 100 guests, and 1 robot.
Topics128,052
Posts1,055,725
#1174199 07/16/2016 8:15 PM
Leo
Offline
Moderator
Moderator
My 261 has a bypass oil filter attached to the manifold. A small amount of oil is leaking at the top of the canister where the bolt holds the cover on. It is not leaking around the top of the canister where the big rubber ring is. Is there supposed to be a rubber seal between the bolt and the canister lid?
Leo #1174202 07/16/2016 8:36 PM
Riding in the Passing Lane
There is generally a copper or aluminum gasket under the bolt.
1972 Chevy c10 Cheyenne Super
Leo #1174223 07/16/2016 11:21 PM
I use an oil drain plug washer/gasket, available at any FLAPS or hardware store. For my truck, the washer that fits the stock oil drain plug is the same size that fits the filter bolt.
Matt
Leo #1174345 07/17/2016 8:46 PM
I had that problem for a while and I replaced the washer with a new copper one. I think the old one was copper and got work hardened.
1951 1 Ton Completed
Leo #1174367 07/17/2016 11:00 PM
Leo
Offline
Moderator
Moderator
Thanks for the replies. I put a thin washer in there with a bit of silicone for now, will look for an oil drain plug as Matt suggested.
Leo #1174378 07/18/2016 12:18 AM
Ex Hall Monitor
Ex Hall Monitor
FWIW my filter's bolt has a cup shaped washer. I replaced the gasket material that was in the 'cup' with a rubber washer from the hardware store and all is good.
