3 members (FishinToms53, Gdads51, Gray_Ghost), 80 guests, and 0 robots.
Topics128,052
Posts1,055,740
#1173841 07/14/2016 2:12 PM
Z
Z Offline
Does the positive + side of the coil go to the distributor ????
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
If you're using a negative ground system, the (+) side of the coil connects to the ignition switch (or the ballast resistor). The (-) side goes directly to the distributor with nothing connected in between.
Z
Z Offline
THANK YOU JERRY....
