| | | Forums66 Topics128,089 Posts1,056,439 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2016 Posts: 2 Moderated | | Moderated Joined: Jul 2016 Posts: 2 | New to the forum. Looks like the place to be! I'm restoring (complete frame off) 1950 6400 flatbed to go into service delivering hay. Lots of heavy lifting done so far and now rebuilding the brake system. Have broken rear brake shoe return springs and am trying to source originals or get a cross to something available. Any suggestions? | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | welcome to the site! I went to a local brake and clutch supply shop and got some numbers for my 58 2-ton. They did not have any in stock but I ended up finding a new set on Ebay. If that doesn't work out, you may also try posting an ad in the parts wanted section | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy hay man, welcome, Jim Carter has his part number ME148 which are 5/8" X 7", I won't quote a price as my catalogue is a few years old, hope that helps. | | | | | Joined: Feb 2011 Posts: 27 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2011 Posts: 27 | Just installed a pair of the ME148 return springs on my 39 1 1/2 Ton COE and the fit like advertised. | | |
