5 members (bnauman, Oswald, 3B, dt235sd, Bill Hanlon), 84 guests, and 3 robots.
Topics128,175
Posts1,057,115
Members48,463
#1173066 07/08/2016 9:44 PM
My stock 1953 SM420 4 speed transmission has the wind back front seal. I can not keep it full of 90 wt mineral oil. By full I mean within a half inch of the fill plug. The tans operates properly however oil leaks out the clutch cover. In a few hundred miles it is below where you can touch with your little finger. Question how full should I fill this transmission?
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
Sir Searchalot
Sir Searchalot
should be kept even with filler plug hole. 1/2 inch down max.
Thanks bartamos, that is what I thought.
1953 Chevy 3100
261 and SM420
53Chevy 3100
1953 Mack Firetruck
1972 Porsche 911
1986 Honda Goldwing
Mine leaks like a stuck pig, too. Although I don't think it's leaking out through the front yet.
1950 4100 - unrestored and driven weekly for almost no reason at all.
To the filler plug hole when oil/transmission is hot.
About 1/2" below the hole when oil/transmission is cold.
