Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (klhansen, carbking, 1 invisible), 252 guests, and 3 robots.
Topics128,283
Posts1,058,521
Members48,490
Junior Member
Junior Member
I'm in need of some direction in regards to....
what is the best body filler out there that you guys have used and had great results from???
I was told that Evercoat's "Rage Extreme" is supposed to be great stuff as well as Tiger Hair....was told to use tiger hair and then a filler over that for areas that are rough, like around welds that have been grinded down but need filler, etc.?? Any advice is greatly appreciated!!?? Well I need some good advice as quick as possible because I'm looking to get my '50 GMC in filler and ready for primer by Tuesday if not sooner!
Thanks in advance guys!!
Jason
Tab Offline
I just use good ol Bondo but only because it's cheap. lol.... Seems to last though. I've had my truck for 22 years.
delete my account and pictures
Tab Offline
and WTF is with the name "rage extreme" LOL!!! It's just body filler. It's only a matter of time before they come out with, rage extreme suppositories.
Here's what the say about the R E Body filler. I think that you could put this same verbiage on the extreme suppositories. hahaha...
"formulated with advanced air release agents and self-leveling properties that, when mixed and applied properly, allow trapped air to migrate to the surface and release"
Insomniac
Insomniac
I have witnessed "rage extreme" when the body filler didn't kick off properly due to old catalyst! eek
Gord 🇨🇦
1954 1/2 ton 235 4 speed
I have used Rage Gold and Extreme with good results...
Andy
A man is like an old truck... He will rust out before he wears out...
if you use extreme or other finish coat filler for your last coat you will be hooked it saves time and looks good easy to shape coat the whole panel in one pass sand till its paper thin and ready for paint
There IS a difference in plastic fillers. Some will spread and sand better than others. Personally, I use RAGE or RAGE Extreme.
“Basics of bondo types”
"Regular" polyester body filler, and polyester "putty" is basically the same thing. They are both, you guessed it "Polyester" based. Polyester is what fiberglass is made of. The fillers have talc and some other components that give it "body", that is the basic difference between fiberglass resin and polyester body fillers.
The Putties have a finer ground talc than "regular" filler. They cost MUCH more, but are well worth it for skim coats and minor repairs. Being they are polyester they use a hardener and CURE like fiberglass.
The old "spot putties" DO NOT use a hardener and are simply lacquer primer . They are JUNK and should not be used.
Some examples of these products are as follows.
“Reinforced” polyester fillers:
These can be aluminum filled body filler for metal surfaces. I is very hard to sand and not good for the finish work (needs a skim coat of a “reg” filler or polyester putty) but will fill much more per coat reg filler and has more corrosion resistance.
A Fiberglass reinforced filler is similar.
Examples are:
Evercoat’s “Metal-2-Metal”, “Everglass”, “Kitty Hair”, “Tiger Hair”
3M’s 05815 Short stand filler, 05813 Long strand filler.
"Regular" polyester body fillers:
Evercoats RAGE or "Lite weight" and others.
3M's Lightweight body filler #058001
Polyester putties:
Evercoat's "Polyester glazing putty", "Easy sand" and others.
3M's "Flowable finishing putty"#05824 or "Piranha"#05821 .
"Spot putty" (junk, not recommended) Usually found in a toothpaste tube looking container.
Evercoat's "Ever-glaze" #403
3M's "Acryl-green" red or blue #05960,05964,05966
Dupont’s 2286S, PPG’s DFL17
I personally recommend Evercoat products.
“Basics of Basics” Plastic filler
By Brian Martin
What ever tools you use the trick is to not add the last "skim coat' till you KNOW that it is all you need. Don't try to block out that first coat, just use it as a base for the LAST skim coat.
I was taught this procedure after doing bodywork for a number of years and it really works well:
Just apply a nice coat of filler (what ever brand, whatever style, we will put that aside right now). Cut that coat NOT to make it perfect, but to get the basic shape and filling you need as a base for the skim coat. You can cut it with 36 40 or 80 depending on how big the area you are working is. In other words, if you can cut it fast with only 80 then do it. But I would say that this would be limited to an application that is no larger than about 8 inches.
If you happen to have a few high spots, see if you can tap them down.
If you have a few low spots add a bit more filler to ONLY those spots.
Re-cut these last low spots you have just filled with the same grit you have been using (most likely 36).
If you now have a surface that ONE skim coat will fill, then apply it. If you don't work with it a bit more, but NEVER add a little here or there and think you will finish it without a skim coat.
If you have a surface that is very close with only a few VERY MINOR low spots like poor feathering onto the metal, poor transitions from one application of filler to another, or from the metal that is "poking" up here and there you can do the LAST skim coat.
This skim coat is very important, you want it to extend over the COMPLETE area, this is well past the damage you have been working. Maybe as much as 3 inches past the plastic that you have applied to "rough" it out.
This skim coat can be regular filler or a polyester glaze like "Icing" or "Polyester glazing putty", that is your choice, I use both depending on the size of the area being worked. Do not use anything that doesn’t mix with a hardener. NO, “Spot putty” in a tube, only polyester putties or fillers. If it uses a hardener, it cures to a hard film. The “spot putties” stay soft and can become even softer when the solvent from the primer coats it.
You now run a block, long board, or hog even over this skim coat with a little bit coarser paper than you plan on finishing with to cut off the resin that has surfaced in the filler. I usually just use the 36 or 40 or whatever I have been on the "rough" work. BUT take CAUTION not to cut much off, you want to JUST take the very top, don't really sand AT ALL.
Now finish sanding with your longboard or block or hog or whatever using the finer paper like 80 on a large area or 120 on that small 8" sized area. Block it out to perfection with a nice feather edge to the surrounding metal.
I can't stress enough, the trick is to know when just ONE LAST skim coat will do the job. And apply it COMPLETELY over the surface. If you only one little low spot in the middle, DON'T just do it, skim the ENTIRE thing. You HAVE to have one LAST skim coat over the ENTIRE thing every time. If you get in the habit of this you will do it over and over on every dent you repair and find that you can do just about any dent with just
two applications.
As you sand the filler let the board or block you are using run over the surrounding metal. If you only work on the filler you will sand it too low. You need to keep it as high as the surrounding metal, so use the metal as sort of a straight edge that you run the block or board off of.
Don’t worry if you cut through this skim coat here and there. In fact, you WILL most likely cut through. The point of that "LAST SKIM COAT" is that after you add it, you don't add ANY MORE filler. That "LAST SKIM COAT" is just that the LAST filler you add. If you hit a little filler below, or metal, that is normal and fine. The only thing you are looking for at that point is if the panel is FLAT. The filler skim coat is serving no other purpose than to finish you filler work, it is not a "sealer" or anything like that.
You can add fiberglass resin (“A” coat if you have a choice) adding the resin was exactly how I learned from the great Emery Robinson (my personal hero in the auto body world). But remember there was no products like polyester putties back then. When you add resin, that resin comes to the top of the film of filler. It is then something you have to deal with. The whole purpose of the SKIM COAT is to put a layer of filler over the top that is easy to block out with as little effort as possible. You want to be able to concentrate on making the panel FLAT not fighting with gummy resin, sand scratches and the like.
So the polyester putty though expensive is what I use.
How is this for an idea, a co-worker of mine showed me this very obvious tip. smile
Add pour-able polyester putty to the regular filler! What an idea! LOL A little pour-able squirted into the "bondo" really thins it out nicely.
The "LAST SKIM COAT" should be left to cure a good long time. Where you may jump on filler and sand it as soon as it is hard, the skim coat should be GOOD AND CURED for an hour or more. If you can of course, in the production shop you may not be able to wait that long. The benefits of the procedure will not be diminished.
A little added note, I have found that I don’t use 36 or 40 grit at all anymore. I went to work at a shop that didn’t use the coarser grits so I had to learn not to also. I have found that using just the 80 and then finishing the Skim coat in 120 or 180 works great, even on large panels.
At this shop it was the first time that I wasn’t doing my own primer work. This meant that I couldn’t “cheat” with a lot of primer and blocking the body work “one more time”. I found that I had to get the work PERFECT, then give it to the painter. I did this in an interesting way, I look at the last skim coat as even a more “final” step. I now look it as “primer”. You see I have used polyester primer, which is like spraying “bondo”. They are both polyester resin based and act and sand very much the same. So, I figured why not just “spread out my primer” as the skim coat! It has worked GREAT, the painter jokingly says, “do you think I’ll need to prime this or just paint it?” I tell him, “Just clear it, it’s a shame to hide that work under primer”.
This method has worked great for me, it’s more of a state of mind than a procedure.
And don’t be afraid to buy the best sand paper and use a lot of it, the cost of the paper will be nothing next to the time and muscles saved. Find the paint store in town that services the PROS the Body shops in town, that is were you will get the right stuff and the right info.
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
It's hard to beat good ol' bondo.
Making chicken salad out of chicken sh!t.
1955 Ford F100
1954 GMC
Junior Member
Junior Member
hey thanks guys!!
Yeah, i went over to Eastwood Co. a few days ago (I live about 40 minutes away) and scored a GALLON of the rage extreme body filler fora whopping,..$20 bucks!! As fourtune has it, it was in with the 1/2 priced stuff because it was a dented can,..no damage, no outdated crap,...it had been in a box that was damaged and another can in the box popped open, so this was put out,....I scored big time on that!!
A friend who got done with his '50 Chevy fleetline custom with 50 caddy tips moulded in has been helping me with my truck,...the rage extreme stuff seems pretty good thus far,....!!
Jason
