3 members (MickeyP, 2-Ton, 1955 1 Series), 122 guests, and 1 robot.
Topics128,115
Posts1,056,624
Members48,450
Hello All..I am rebuilding my 1964 C10 and have hit a road block. On my lower control arm, one side will not accept the cap threads that hold in the control arm bar. I have swapped the caps to the other side and it threads as expected. Any suggestions? Does anyone know if it is a 1 5/8" tap? I would prefer to "fix" this rather than replace the piece. Please let me know!
Best Regards
The Forge Dude
I do not know what size tap is required.
Question, are you doing this under load (is the spring installed). I doubt you are but wanted to ask.
If you cannot get it to start you may have to get a new rod for the cap to attach to.
Hi Rusty64, Nope the control arm is off the truck. The rod itself is fine and spins into the cap, it is the threads on the control arm that are mucked up.
Riding in the Passing Lane
Weld the cap to the control arm.
1972 Chevy c10 Cheyenne Super
Howdy Wrenchbender! I thought about doing that as a last resort (okay last resort was buying a new control arm hahaha) I am going to attempt cutting new threads with my Dremel, I figure several strong cups of java will counter the normal shakiness of my skills. Thanks for the tip!
Best Regards,
The Forge Dude
Take it to an Automotive Machine shop or auto repair shop.
They will have an assortment of dies. Surely one will fit.
Harold
Harold
