10 members (Bill Hanlon, Otto Skorzeny, BarryP, mick53, rfs56trk, Nick in Manitou, UtahYork, NorCal52Suburban, Hanks custodian, 1 invisible),
113
Mod | | | Forums66 Topics128,136 Posts1,056,745 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Replaced all four cylinders and all rubber hoses. Adjusted all pads according to the manual. Bled the system 3 times. Still pedal goes to the floor when pressed. Whats next?
Andy
Sometimes you're the window Sometimes you're the bug
| | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Master Cylinder. Look for pits from rust.
Steve H
| | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Best to rebuild or replace
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | Best to rebuild or replace Its best to rebuild it if it doesn't have pits in the piston travel area that can't be honed out. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Update, Master cylinder was replaced, to many pits. Bled everything I think. Now have the issue of having to pump the brakes to get them to work. Is that a sign of air still in the system? If not, any ideas?
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Did you bench bleed the master cylinder? If you have the under floor master then look into 10 pound residual valves to hold pressure on the drums. Yes, it might be air but have you adjusted the shoes for a slight contact?
| | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Master cylinder was bled per manufacturer instruction. Brakes were adjusted so the pads rub then backed off a few clicks. What is a residual valve and where do you find one?
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Residual valve is a one way check valve. They are used inline with the brake lines to keep a certain pressure on the shoes or pads. In you case with all drums you need a 10 pounder (2pounds for disc). They are considered necessary for systems where the master cylinder can be below the brake cylinders. Fluid runs downhill so the fluid in your lines can run back into the master cylinder. They are usually located near the master cylinder. You will need one for all lines leaving the m.c. They are around 1/2" in diameter and about 2" long with tube connections on the ends. Cost around 8 to 10 bucks.
| | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | So it keeps 2lbs of pressure on each cylinder. Sounds good Thanks
| | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | 2 pounds for disc and 10 pounds for drums.
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Usually if you can get a solid pedal on the second pump, it is an adjustment problem. I would adjust the shoes so that they are tight and then back off to where there is still some drag. | | |
