1 members (Hotrod Lincoln),
112
Mod | | | Forums66 Topics128,142 Posts1,056,491 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 26 | Inherited this I-6 that was completely disassembled and supposedly rebuilt. Everything looks new inside but it appears to have hydraulic lifters (the insides move up and down when pressing on them with a push rod). I don't see any reference in the shop manual as to how one properly adjusts these lifters. Only solid lifters are addressed.
Do I adjust to zero lash plus one turn like the V-8's? Or do I simply collapse the inward portion of the lifter and set lash then? Or what? The manual is of no help. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | http://www.stovebolt.com/techtips/valveadjustment.htmdown towards the bottom, it says, "It has been brought to my attention that I didn't give the final adjust for hydraulics -- Tighten down until no noise is heard (use a section of hose to your ear and to the tappet if needed) then tighten one(1) complete turn." | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Just a note of interest that someone can expand on or shoot down. I am under the impression that the cam made for solid and hydraulic lifters are different and don't interchange. If that is true then I would think you would need to take the time to check that cam to make sure it's the right kind. Now to see what the gear heads say.
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Inherited this I-6 that . . . appears to have hydraulic lifters. . . . I don't see any reference in the shop manual as to how one properly adjusts these lifters. Only solid lifters are addressed. . . . The manual is of no help. The truck Shop Manuals only describe procedures for truck engines. Because, hydraulic lifters were only used on car 235 engines. 49-53 Car Shop Manual - hydraulic lifters 50-53 1955 Car Shop Manual - 6 cylinder | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Yes the cam profile is different for solid and hydraulic lifters. Very different. The "ramps" are what matters. The lift and duration can be much the same, but the way the lifter is accelerated matters a lot.There are some very good Tech Tips for adjusting both types. Do a search.
Steve H
| | | | | Joined: May 2005 Posts: 215 Shop Shark | | Shop Shark Joined: May 2005 Posts: 215 | Somehow my 59' truck motor has hydro lifters | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | somehow the engine may have been changed in the last 57 years, have you checked the numbers on it? or maybe it's also got a hydramatic trans?
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Trucks with Hydra-Matic transmissions did not come from the factory with 235s with hydraulic lifters.
All Powerglide-equipped car 235s had hydraulic lifters. All car 235s from 1956 onwards had hydraulic lifters.
However, all 235s from 1958 onwards were set up for hydraulic lifters. Someone could have placed hydraulic lifters into this 1959 truck 235.
Trucks that came equipped with a Powerglide transmission in 1960 and later might have had hydraulic lifters.
What is the Engine Serial Number in your 1959 235, biglou? (it is pressed into the block to the rear of the distributor). What is the block date casting code? | | |
