| | | Forums66 Topics128,264 Posts1,058,357 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | What carb would you recommend? I was going with a 390 but was reading that a 500 might be a better option. Engine is being built with a 3/4cam .60 pistons. For my 58 GMC 1/2ton.
Danny 1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
| | | | | Joined: Feb 2004 Posts: 29,945 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,945 | What RPM are you planning to run?
Cubic inches divided by 2, times RPM, divided by 1728 = Cubic feet per minute.
For instance, a 302 running at 4K RPM has a theoretical CFM of 305. In practice, the real CFM will be 85%-90% of the theoretical number due to intake and exhaust restrictions, failure of the cylinders to empty effectively on the exhaust stroke, etc. In real numbers, your 302 at 4K RPM will be flowing about 314 CFM. Jerry
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Just going to be a street engine. Going in my 58 GMC 1/2ton truck
| | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | Anybody have a GMC302 in their truck that might want to comment.
