1 members (Peggy M),
321
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 54 | I'm trying to find out what the clutch disc size is on my 1959 Chevrolet Apache 3600, 4-speed, 235cu, before I take out the tranny and replace it. Classic Chev Parts of America shows a 10 1/2 inch. O'Reilly's has a 10 or 11 inch. Thank you. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | It's a gamble if you try to guess what is in there. There could have been changes made over the past 50+ years.
And, as you probably know, 10" or 11" were original equipment sizes.
I always take mine out and take the assembly into the parts store - if they are willing/interested in measuring/matching what I have.
Otherwise, I measure the distance between opposite-sides pressure-plate mounting holes and get a complete assembly that bolts up to those holes. | | | | | Joined: Jun 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 54 | Thank you, will do as you suggest. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | Brake and Clutch in Seattle, on 6th just N. of Spokane st. should have them sitting on the shelf. Good parts, no junk! Good guys in there too! They will look at it, walk in the back ,and come back with the whole kit for around 180$. No need for them to look that up normally. I have been going in there for 25-30 years. | | | | | Joined: Jul 2010 Posts: 592 Shop Shark | | Shop Shark Joined: Jul 2010 Posts: 592 | I had the same question last November when I replaced the clutch on my '57 3600. The 10" was standard, but the 11" was an option on the '55-'59 3600's. Turns out I had the 11" clutch, but had purchased the 10". My local O'Reilly had the 11" in stock, so I got lucky.
I would buy both so that you have them both on hand and return the one not used.
The 11" does not allow much wiggle room to get in or out, especially if you are doing it on your back. Be patient.
Good luck,
Matt | | | | | Joined: Jun 2013 Posts: 54 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 54 | Mike, Thanks for the tip. I'll check them out. | | |
