2 members (lumbersawyer, 78buckshot), 167 guests, and 3 robots.
Topics128,142
Posts1,056,474
Members48,441
#1172491 07/04/2016 8:26 PM
I need to replace the leaking gasoline shut-off valve and gas line running to the fuel pump. I will order new parts.
I am scared to work around gas tanks. Does anyone out there have some good suggestions on how to safely approach this issue? The tank has about 5 gallons of gas in it. I know I have to put this gas in a container, however, I'm very concerned about the vapors and a potential explosion. Any thoughts on how to handle this situation that will put my mind at ease?
"Lucille" ..... Proud Member of the "Southern Stovebolts"
David Wolff
1946 Chevy 1/2-ton
No open flames, no smoking and no grinding or sanding that may produce sparks. Keep a good size working fire extinguisher handy. Really is a reasonably safe operation as long as your careful and insist anyone working around you or with you follow the rules too. Try to do it outside if you can, just more room to get away from a bad situation if need be. You can do it, piece of cake! laalaa
x2
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
Grab a regular gasoline storage can and a big funnel. Drain the gas into the can and store it out of the sun and away from heat sources, etc. Now if you're concerned about vapors, remove the gas cap and attach an air hose to the tank outlet. Run air through the tank for a few minutes and you'll purge out enough vapors to eliminate any risk while working around the tank.
I have soldered and/or welded on gas tanks by filling the empty tank with CO2 or even exhaust gas, to purge the oxygen out of the tank. No oxygen, no possibility of fire or explosion!
Lucille #1172521 07/04/2016 11:03 PM
Think of it as you would when filling up your tank at a gas station. Common sense dictates no open flames.
Handling gas only gets dicey when you have a significant spill. This generates lots of fumes. Gas as a liquid is not as dangerous as one would assume. You can have a stable jar of gas and actually snuff out a lit match in it. DO NOT TRY THIS!!!. I was a very young, ignorant, grossly unsupervised, young lad when I discovered this stupid fact (right after I learned that a Styrofoam cup was the world's worst choice of a container for pouring gas into).
Carl
When I drained the tank on my 38 master, I used siphon tube with a starting bulb on it. It took a while but with the tube in the gas can, there was very little fumes. I was concerned too and it was inside my garage in winter.
1951 1 Ton Completed
Don't use a trouble light with an old school bulb,..... gas on bulb, bulb pops, big fire or explosion.
Crusing in the Passing Lane
When welding fuel tanks, etc., I always fill with water, then tilt the tank so weld area is just above water line. Alcohol rinse tank mixes with any remaining water, removing all traces.
Ed
Big Bolt Forum Moderator
Ed
My dad did that years ago, blew himself out of the garage! I like Jerry's idea of filling with exhaust gas or ever putting dry ice in it to get rid of oxygen. Too much oxygen in water! (although I am too chicken to weld on a gas tank myself!)
Mike
If you're scared to work around gas tanks and gas fumes it will be well worth the peace of mind to have a professional do the work for you.
1951 Chevy Panel Truck
The idea of welding a gas tank sort of freaks me out.... eeeek
But then again... I'm not a welder not did I stay at a Holiday Inn Express last night.
Micah
Located comfortably south of Atlanta, GA
1948 Chevrolet 6400 Loadmaster 2-Ton -in progress
"Lucille"
More pix on Flickr
Follow the story in Big Bolts
I welded a hydraulic tank a few months back, I drained out as much oil as we could, then power washed what was left. Before welding, I ran a hose from the tail pipe into the tank opening. This removed the oxygen, so no oil explosion!
With todays modern gasoline, a few days laying out in the direct sun will dry out all the fuel and vapors. Ace Hardware and I'am sure other stores, sell fire extinguishers in small spray paint sizes cans. These are nontoxic, Halon "type" which when sprayed removes all oxygen from the area. They would work great for this type of welding.
joe
