9 members (Gib70, Gdads51, 78buckshot, Phak1, mo2cyl, Oldcaliforniakid, BC59, Wally / Montana, MickeyP),
81
Mod | | | Forums66 Topics128,049 Posts1,055,667 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11724 08/05/2002 6:58 PM | Joined: Apr 2002 Posts: 15 Member | | Member Joined: Apr 2002 Posts: 15 | Hey fellow truck nuts!!!!!
Took my wife's 54 for a short cruise this past w/e. And NO speedo? I have had a couple cars strip the gear in the tranny. Can you still get the gears? Any other poss?
Thanks a heap!
Jim | | |
#11725 08/05/2002 10:31 PM | Joined: Feb 2002 Posts: 167 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2002 Posts: 167 | Hi Jim,
It could be a number of reasons why the speedo is'nt working, here is few things to check. Does the cable fit at both ends? If so, check to see if the magnet is demagnatised inside the speedo. Is the cable lubed? Did the square cable break off in either end of the housing? Is the back of the speedo housing were the square cable go,is it striped? Or the other end were the square cable goes into the side of the tranny? I think I might be missing somethings to check.
Chevyboy62
My truck don't leak oil, it just marks its teritory.
#11726 08/08/2002 3:52 PM | Joined: Apr 2002 Posts: 15 Member | | Member Joined: Apr 2002 Posts: 15 | Thanks for the info. I was not aware of the magnet idea. I checked the under dash, and everything looks fine and in place. I will pull the cable line off the tranny and remove the cable to check it out later tonight...
Just "one" last thing to fix and then were done...right...
Jim :rolleyes: | | |
#11727 08/08/2002 7:12 PM | Joined: Jun 2000 Posts: 2,773 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 2,773 | Usually the cause is a lack of lube in the cable, and you find the cable either broken or frayed or all twisted up. If the cable is okay, check the speedo gear in the tranny, then the speedo itself. If you need any parts for the speedo itself, call Jeff at Bowtie Bits, part of his business is rebuilding speedos and gauges. Be sure to lube the cable with the proper speedo cable lube.
Fred 52 3600 69 C-10
#11728 08/09/2002 1:42 AM | Joined: Dec 2000 Posts: 64 Member | | Member Joined: Dec 2000 Posts: 64 | An easy way to see if the cable and speedometer are OK is to disconnect the cable housing from the trans. and spin it with your fingewrs and see if the speedometer hand moves, or connect the cable to a variable speed, reversable electric drill and turn the cable that way. If the speedometer doesn't register you know to start checking the cable or the speedometer head, if it works then the problem is in the speedometer gear, either stripped, cable not engaging in the gear, or the transmission gear is loose on the shaft or stripped. It should not be to hard to find the problem.
kdot em3
