9 members (jmoore, KEVINSKI, Bucker, 55shaker, 3B, papas52, 2-Ton, Joe H, GMCJammer51),
92
Mod | | | Forums66 Topics128,157 Posts1,056,894 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 26 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 26 | Can anyone please attach a picture or give me a clue on how the door check/hold open bracket fastens to the body? There is a hole in the door jamb but I dont know how the bracket fits in this rectangular hole. Many thanks Steve | | | | | Joined: Jun 2016 Posts: 236 DLBrooks | | DLBrooks Joined: Jun 2016 Posts: 236 | You can lightly compress new ones in a vice - do not scuff - remove and install -- and once in apply grease lightly to both sides. Rubber will be toward inside cab. see pic. http://67-72chevytrucks.com/vboard/showthread.php?t=711364
| | | | | Joined: Jan 2013 Posts: 45 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2013 Posts: 45 | Steve, the door check go behind the kick panel on the 41-46 truck. there should be a bracket that welds in the inside if the door and two tab come thru the hole that the check fits into. these is a stub that goes thru the tab and the round end of the check and lock in with a clip. you may have to play with the check to make sure you have it in correctly, it only goes two ways. the door tab may be missing, but Jim carter and Chevy of the 40 sell them. Good luck Jerry
My first prewar and it will not be my last. Done with the 40 for my best friend. Got a 46 (year I was born) to build for me.
| | | | | Joined: Aug 2013 Posts: 26 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 26 | Dennis Thank you very much for your response and picture. It was really simple thanks to your response. Steve | | |
