5 members (JW51, C10 - C90 Bill, Gray_Ghost, Leo, Hotrod Lincoln), 111 guests, and 2 robots.
Topics128,100
Posts1,056,177
Members48,436
#1172263 07/02/2016 10:21 PM
I'm hoping someone here has run into this before.
I bought my truck without a motor or the front motor mount. I've been looking off and on for about 6 months and the mount isn't reproduced, only the rubber insulator and oil shield.
Short question is, has anyone made one? Is there an alternative way mount the engine in front? I've only seen a few photos of the mount so I don't really know what it looks like assembled, but it seems like all I need to do is attach the front mounting plate to the frame cross member with some type of rubber cushion.
Am I on the right track here? Has anyone come up with a workaround for the front mount? This is for a 1950 Chevy 3100 with a six cylinder engine.
Thanks!
Rodger
1950 Chevy 3100 Short Bed
Work in Progress although both are debatable!
If you can find a used/no good one there are places that rebuild mounts. Just had a rear pair done for a 40 Pontiac 6. As along as you have the steel part they can mold the rubber part. If all else fails go to your FLAPS and look at the transmission mounts as many of them are rectangular with studs/bolts on both the bottom and top. Probably have to drill holes to fit in front engine plate. For much more stable engine mounts weld an arm off each side of the front plate and use flathead Ford mounts. Corvette did this and had the mount plate attached with the water pump bolts.
Evan
That's a good idea on the transmission mount. I may be able to get something close and modify it from there.
Thanks!
it is reproduced but on back order
...on back order...
parts wanted ad might help you
Somebody must have one laying around, go to the parts wanted topic.
1946 1-ton Panel
1952 1-ton Comml. W/Grain Body
No complete plans here but some ideas or guidance. Denny does nice work.
Good luck, have fun.
1947 3100 Advanced Design
Never, never, never, never give up. - Churchill
Thanks for the link, Bill. That helps explain a lot. Hopefully, I'll be able to come up with some of the pieces. If not, that'll give me an idea what needs to be done.
I really want to get back on track with this project.
Rodger
1 Offline
I may have a mount for you. Is it the one that bolts to the timing chain cover mount? Or the one with one bolt that has a u shaped mount with two bolts on each side? I have one of each.
Trombones Totem Poles And Old Trucks!
It bolts to the plate behind the timing cover.
Mount
This is the one I'm looking for.
Thanks!!
Rodger
1 Offline
I have one I can sell you. Send me a message and we can trade info. I have a rubber piece also.
Person-to-person buying/selling/trading/gifting should take place in Private Messages or in email.
This avoids cluttering up a useful thread with info that is has no long term usefulness.
1 Offline
And that's exactly why I suggested he contact me by message. Every time I post on this site I get over moderated. Then I go away for a year or so because its not worth it to even try and help someone out. Forget it!
Well Dan, rules are rules. Read the user manual on the Home Page and do your best to follow the rules. When you get caught don't take it personal just tell yourself "I need to do better". Getting mad and leaving does nothing for you or the site. Hang around and enjoy yourself, it's a lot less stressful.
Stick around, Dan
You could have used email and you could have used PM - them's the rules.
