| | | Forums66 Topics128,277 Posts1,058,453 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 863 Shop Shark | | Shop Shark Joined: Jul 2013 Posts: 863 | I have 2 rebound clamps broken on the passenger side rear spring and 1 rebound clamp broken on the driver side rear spring. Thinking about using the Kwik clips by ATS to fix this problem. Question: What is the best way to remove the remaining piece of the rebound clamps and rivets from the leaf springs?
Tim
1949 Chevrolet 3100 Series 1/2 ton Pickup 1964 Chevrolet C10 (Ol' Yella) (SOLD) 1958 Chevrolet Biscayne 2 door (SOLD) 1970 VW Beetle
| | | | | Joined: Feb 2000 Posts: 5,268 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,268 | The rivet will stay in the spring, at least part of it will. Grind off or chisel the head and pry the remaining clip piece off. The finish grinding the rivet flush with the leaf.
Joe | | |
