Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (Shade Baby, 55shaker, Pre '68 Dave, 1 invisible), 106 guests, and 3 robots.
Topics128,277
Posts1,058,453
Members48,490
I have 2 rebound clamps broken on the passenger side rear spring and 1 rebound clamp broken on the driver side rear spring. Thinking about using the Kwik clips by ATS to fix this problem. Question: What is the best way to remove the remaining piece of the rebound clamps and rivets from the leaf springs?
Tim
1970 VW Beetle
The rivet will stay in the spring, at least part of it will. Grind off or chisel the head and pry the remaining clip piece off. The finish grinding the rivet flush with the leaf.
Joe
