2 members (Stovebolt48, 1 invisible),
131
Mod | | | Forums66 Topics128,211 Posts1,057,473 Members48,473 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | | | | | | Joined: Feb 2001 Posts: 1,897 Member | | Member Joined: Feb 2001 Posts: 1,897 | :rolleyes: I have been watching that one....
| | | | | Joined: Apr 2003 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 67 | pardon my naivety, but what is a dukw or a cckw ?
Royzell | | | | | Joined: Aug 2000 Posts: 346 Shop Shark | | Shop Shark Joined: Aug 2000 Posts: 346 | royzell,
I think they are military trucks produced by GM.
'38 Chevy 1-1/2 ton '49 Chevy 1/2 ton '54 Chevy 6400 2 ton '55.2 GMC 3/4 ton '56 GMC 1-ton
No Room Left in Shop
| | | | | Joined: Apr 2003 Posts: 67 Shop Shark | | Shop Shark Joined: Apr 2003 Posts: 67 | ol blue, thanks for the info.
Do you (or anyone else) know the horsepower and torque specs on the 302 ?
I could be tempted...
Royzell | | | | | Joined: Jul 2003 Posts: 101 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2003 Posts: 101 | Seller replied to me that it's out of a 54 GMC bus and that the serial number of the motor is n 375182 cal 302 7905 | | | | | Joined: Jan 2000 Posts: 206 Member | | Member Joined: Jan 2000 Posts: 206 | Stock 302 output was advertised at 146 bhp at 3300 RPM and 270 ft/lb (no RPM specified). Most of these engines were equipped with governors to limit output. I have some factory dyno prints from 196? that show somewhat higher numbers from a 302 with no accessories or muffler, and optimum spark advance: 168 HP at 3600 RPM and 275 ft/lb at 2400 RPM. The torque curve is virtually flat from 1200 RPM until it starts dropping off at about 2600. | | | | | Joined: Jan 2001 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 687 | This ended up selling for over 500 dollars!  Was the winner a board member? | | | | | Joined: May 2003 Posts: 68 Member | | Member Joined: May 2003 Posts: 68 | Just a reminder that I have a 1956 gmc 2-1/2 ton with 302/5-speed. Email me if you want more info.
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
#1176 10/16/2003 11:21 AM | Joined: Sep 2003 Posts: 23 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2003 Posts: 23 | I have a 56 GMC as well and would be interested in any information you may have collected if you have any. so far my searches turn up very little on these big trucks.
