0 members (), 75 guests, and 3 robots.
Topics128,211
Posts1,057,475
Members48,473
:rolleyes: I have been watching that one....
pardon my naivety, but what is a dukw or a cckw ?
Royzell
royzell,
I think they are military trucks produced by GM.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
ol blue, thanks for the info.
Do you (or anyone else) know the horsepower and torque specs on the 302 ?
I could be tempted...
Royzell
I
I Offline
Seller replied to me that it's out of a 54 GMC bus and that the serial number of the motor is n 375182 cal 302 7905
Stock 302 output was advertised at 146 bhp at 3300 RPM and 270 ft/lb (no RPM specified). Most of these engines were equipped with governors to limit output. I have some factory dyno prints from 196? that show somewhat higher numbers from a 302 with no accessories or muffler, and optimum spark advance: 168 HP at 3600 RPM and 275 ft/lb at 2400 RPM. The torque curve is virtually flat from 1200 RPM until it starts dropping off at about 2600.
This ended up selling for over 500 dollars! eek Was the winner a board member?
Just a reminder that I have a 1956 gmc 2-1/2 ton with 302/5-speed. Email me if you want more info.
Heavy metal worker--up to 4-inch plate.... If you can't cut it, burn it!
I have a 56 GMC as well and would be interested in any information you may have collected if you have any. so far my searches turn up very little on these big trucks.
