Brrrr
place holder
6 members (Charles in CA, Gdads51, klhansen, 2-Ton, joe apple, Forty9), 163 guests, and 1 robot.
Topics128,274
Posts1,058,428
Members48,489
#1171805 06/30/2016 1:36 AM
If there is no vacuum sent to the read end does the truck stay in high speed gear of 6.03 or does it stay in the low speed gear of 7.98?
Jeffrey
The 2-speed used in '46 was a mechanical shift unit with a short lever just about under the driver's right thigh. There is no vacuum involved. I have one here in a parts truck I bought with the idea of putting it in my farm truck, but haven't gotten to it yet. If you want, I could send you some pictures.
Camp Commandant
Camp Commandant
The 2 spd in my '46 is vacuum operated. Jeffery, I would think that if the vacuum part of the system is not operating at this time that rear would be in what ever position it was last shifted into before it lost vacuum. But, if you wanted to get it in high and drive it as is, I suppose you could manually shift it. Here is a bit of info from the 2 spd tech tip ( http://www.stovebolt.com/techtips/2-speed%20axle.htm )
"Obviously the biggest thing different about the Advance Design and other older 2-speed rear axles is the vacuum shift unit itself. The easiest way to check the operation of the two speed (especially if the driveshaft is disconnected or the axle is out of the truck)is to use a vacuum source to shift the axle from one range to another while turning the pinion yoke by hand. You can feel the unit shift. A small hand operated vacuum pump is useful. On some units, the vacuum diaphragm can be removed and the unit shifted mechanically."
~ Billy
1959 GMC 860 | Pictures
3B Offline
Hy 32vld and guys, on my 46 300 series GMC with Eaton two speed, when there is no vacuum the rear axle shifts to low speed range. There is a sign embossed into the shifting control in the cab which says "Park In Low",hope that helps.
