1 members (Bill Hanlon), 138 guests, and 3 robots.
Topics128,115
Posts1,056,288
Members48,439
#1171757 06/29/2016 6:29 PM
1) Can anyone suggest a source for headliner panels for a '49 Burb? I just acquired the bows and ctr braces, need the panels or patterns to cut new ones.
2) Too late now, but would I have been better off to have just had a shop install the headliner without using the stock parts?
I believe Jim Carter and Classic have the panels listed for sale. I made my own out of ABS.
It's not hard to make your own panels. Heavy paper, scissors and tape will be your friend. Just do one panel at a time.
Your Burb looks awesome! Did you use the original bows and center braces?
Thank you for the compliment! Original bows, no center braces. They're not needed for the ABS.
I used panels from LMC and it was a time consuming job but not hard at all. My son and a friend helped and it went OK. We started at the back and ended up at the windshield. You will need tagboard to make patterns. We put one section up at a time and then installed the next bow and continued on one section and bow at a time. Not a hard operation but time consuming. Good luck and go to it.
Weeds
