2 members (Hotrod Lincoln, klhansen), 119 guests, and 2 robots.
Topics128,127
Posts1,056,357
Members48,441
#1171610 06/29/2016 12:09 AM
DLBrooks
DLBrooks
Are there any problems with replacing a 1959 GMC 270 inline 6 with a 1953 GMC 302 inline 6? I purchased a 59 GMC half ton with a locked 270/3 speed and I have a chance to purchase a usable 302/4 speed sitting in a 1 1/2 ton grain truck 33k miles.
I will be purchasing rather cheap the complete rolling frame and running gear of which I only need the radiator if it fits, engine, and maybe not the 4 speed trans - have a spare sm420. But I may use the engine bell housing trans --not sure on driveshaft.
Does anyone have interest in the rest or part of the chassis? I should get complete steering and brakes also.
1959 GMC 100 Fleet
Follow in the DITY
The rules are clear, no selling or offers for sales allowed in the forums. Sounds like a cool project. Hope it fits. Others will be along shortly with answers to your questions.
You will need to use the 270 bell housing, flywheel and clutch.
DLBrooks
DLBrooks
Is that only if I retain the 3 speed? I want to end up with a 4 speed.
1959 GMC 100 Fleet
Follow in the DITY
The mounts are different on the frame. You'll need to use the 270 bellhousing with either trans to properly fit the '59 frame.
Bill Burmeister
DLBrooks
DLBrooks
thanks
1959 GMC 100 Fleet
Follow in the DITY
The big truck bell housing and flywheel are too large to fit under the small trucks. The transmission is the same for either.
