2 members (artinva, Chip O),
112
Mod | | | Forums66 Topics128,072 Posts1,055,904 Members48,429 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2011 Posts: 86 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 86 | I am in the process of replacing my control arms. I bought new ones from lmc. The new ones are about a half inch shorter. After trying to raise or lower the axle to make it fit...didn't work ,I measured the new and old...half inch shorter. My question is...can I adjust the drive shaft to make it fit? Any suggestions? | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I would send those parts back and get a refund.
Why are you replacing the old control arms?
Bushings shot?
Why not just get the old bushings out of the original control arms out and match up some new ones?
Will the bushings in the wrong control arms fit your original control arms?
Last have you verified that someone already modified the rear suspension and that your current control arms are not stock? Jeffrey | | | | | Joined: Sep 2011 Posts: 1,453 'Bolter | | 'Bolter Joined: Sep 2011 Posts: 1,453 | Is this for a '65 or '65? Width of pad on axle wider on '60-'62 than '63 up, length may be different, never checked.
BC 1960 Chevy C10 driver 261 T5 4.10 dana 44 power loc 1949 GMC 250 project in waiting 1960 C60 pasture art Retired GM dealer tech. 1980 - 2022 | | | | | Joined: Mar 2011 Posts: 86 'Bolter | | 'Bolter Joined: Mar 2011 Posts: 86 | I was replacing the coils because one was cracked. I had to heat the bolts off because they were gaulded. When I got the bolts out I noticed the holes were badly rounded and enlarged, that with the fact that the previous owner welded patches to the control arms because of the rust problems. I figured it was unsafe,so I decided to replace the arms. I had a friend over last night, and we dropped the drive shaft, and that gave us the room to adjust the axle enough to get the control arms to fit. Thanks for your help!!
