0 members (), 108 guests, and 0 robots.
Topics128,115
Posts1,056,292
Members48,439
Gas Pumper
Gas Pumper
I have embarked on a mission to save a 1953 3100 and replace or repair a lot of the sheet metal. Thought I would share it with you guys. I am always looking forward to ideas on things to do better or different.
http://forums.devestechnet.com/foru...0-tip-of-the-week-38-for-june-19-25-2016
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
looks good
the only thing I would add is on the kick panel.
there are beads that line up with the door
...pic...
Gas Pumper
Gas Pumper
At least I hope they do! I did not know that. I put the panel in from the bottom inside out, so they should. I do not have the door on it right now to check. Interesting. Fitment was OKAY, but not ideal. Some of that could be attributed to the tolerances of the cab itself?
Deve
The Think Tank
ODSS President
ODSS President
THIS is inspiring! As always great write-up. What welder do you have/recommend?
~ Cosmo
1949 Chevy Half Ton
Gas Pumper
Gas Pumper
I have always been a Lincoln Fan. It has to do with their business model and the way they treat their employees as well as the quality of their product. But you are paying for the name. If I were to purchase a new MIG it would be either a Miller or Lincoln that did 110v for mobility and 220 for thicker materials. You cannot lose with either of those. The thing the new guy has a tendency to do is purchase one that does only flux core wire and provides no ability to use Gas. This is a huge mistake and the reason you can get MIGS for $250 or over $1000. Pay the $900 or so for a decent MIG that accepts Gas and you will be happy you did.
Ongoing costs are MIG Wire and refilling the Gas bottle with 75-80% Argon/CO2. A small bottle will last pretty long. Then there are occasional replacement tips and years before the lining in the wire line wears out unless you step on it.
Deve
The Think Tank
Gas Pumper
Gas Pumper
Added this weeks Tip of the Week. Its part two of the above. Due to a busy schedule, its shorter but explains the differences in metal that is exposed vs metal that is hidden. Of course you want to do everything in Show Truck mode, but often things are so close quarters, you can't even get a welding helmet on so you close your eyes and do it blind. Anyway, it's shorter than most but worth the read if you are thinking about doing this sort of thing.
http://forums.devestechnet.com/foru...p-of-the-week-39-for-june-26-july-1-2016
Deve
The Think Tank
One trick us pipefitter pros used for close quarters welding was to put a #10 lens in a set of Acetyline burning goggles and wear a ski mask to prevent getting a flash burn to our faces. It works well for MIG and TIG welding in tight spots.
That doesn't sound like fun.
Gas Pumper
Gas Pumper
I wish I had YOU around Mark! Maybe you would have found a better way, but I have this tendency to stop when I run into things and then take the whole truck apart. I am resisting doing that on this build, so it can make things very hard to get to. The back of the cowl is one of them. It was about a 20 minute job and it's over. I will have to pick up a #10 lens for my torch goggles for next time.
Deve
The Think Tank
Nope, not at all. When the boss says "If you can't do it, you can't get a paycheck!" it's usually a good incentive to get creative!
Bosses! Always giving those motivational speeches!
Some days you just gotta get 'er done!
