| | | Forums66 Topics128,035 Posts1,055,445 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | I saw a post a while back about filling the dimple in my back fender where they used metal and a pattern..I took my side mount off, and want to do away with the dimple..Anyone know anything about this?..Thanks, Steve | | | | | Joined: Jan 2004 Posts: 223 'Bolter | | 'Bolter Joined: Jan 2004 Posts: 223 | You might be better served to see if someone would swap you a fender without the dimple. Folks like these side carriers and are always on the lookout for these fenders and mounts. Or, I would care to wager you could sell the mount and fender, be able to buy another fender and have some change in your pocket. Steve O | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Thought about that, but have no clue on what a side carrier and fender are worth..I would rather have a fellow bolter have it that put it on ebay..Maybe I'll put it in the swap meet.. | | | | | | Anonymous Unregistered | | Anonymous Unregistered | The technique is to cut the dimple out, turn it around and weld it back in place. | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | That will work?..Have a friend who is a great welder, and has a nice rig..I'll have to talk to him and see what he thinks...Thanks, Steve | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I have seen where this method is used to create a indented fender. I looked at doing the reverse process to one of my indented fenders until a good set fell in my lap. Looking at it though it looks like it would work to me. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yeah, I think Houston's referring to the same post you're thinkin of Steve - making the indent in a fender that doesn't have it was discussed some time back, and I think was recommended by MetalMan - no reason the reverse shouldn't work
Bill | | | | | Joined: Feb 2005 Posts: 399 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2005 Posts: 399 | Just went out and looked at the fender, and it might work..Gotta do a little measuring though...Thanks,Steve | | |
