| | | Forums66 Topics128,283 Posts1,058,521 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Got the 54 3100 back from shop. New front brakes rears were fine. The parking brake seems to have too much play in it. Where do you adjust to remove this play? I checked the manual but it is not helpful at all. There are several adjusting yokes on the rod but the manual makes no mention of them. How much play from pedal to foot board when applied? Thanks, Steve | | | | | Joined: Dec 2006 Posts: 1,154 Shop Shark | | Shop Shark Joined: Dec 2006 Posts: 1,154 | Found that pedal adjustment is via the MC rod and 13/16" is the toe board clearance of the pedal information obtained on Chevy online manuals...hope this info. helps others. | | |
