Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (46 Texaco, Bill Hanlon, FAST55, 50Chevy3100, carbking, NorCal52Suburban), 141 guests, and 5 robots.
Topics128,283
Posts1,058,519
Members48,490
Got the 54 3100 back from shop. New front brakes rears were fine. The parking brake seems to have too much play in it. Where do you adjust to remove this play? I checked the manual but it is not helpful at all. There are several adjusting yokes on the rod but the manual makes no mention of them. How much play from pedal to foot board when applied?
Thanks, Steve
Found that pedal adjustment is via the MC rod and 13/16" is the toe board clearance of the pedal information obtained on Chevy online manuals...hope this info. helps others.
