| | | Forums66 Topics128,128 Posts1,056,684 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2004 Posts: 103 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2004 Posts: 103 | I think the PO of my truck used silicon cleaner or wax on my 51. It needs restored and repainted, but I have sanded some areas for touch up and spraypainted a color match. I get the "fish eye" effect. I plan on sanding to the primer, but in places the silicon has permeated through it. What kind of cleaner will clean this up? This will be a daily driver - not show, but I still want a good looking job when it is all done. BW | | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | There are products specifically for this at your local paint store. You don't want to skimp on this.
Wear nitrile gloves when you are sanding and cleaning, too. Your hands and fingerprints contain quite a bit of natural silicon.
Paint & Body Shop moderator A lone amateur built the Ark. A large group of professionals built the Titanic. | | | | | Joined: Apr 2002 Posts: 1,571 Shop Shark | | Shop Shark Joined: Apr 2002 Posts: 1,571 | Never heard of a human body containing natural silicon. We do generate a lot of oils that screw with things like paint, though. | | | | | Joined: Jul 2005 Posts: 11 Junior Member | | Junior Member Joined: Jul 2005 Posts: 11 | I just had some work done on my truck and I use alot of silicone. The fella at the body shop said to wash the truck including tires and steering wheel with ivory dish soap this removes all wax and silicone. infact he said any type of dish soap will work but he mentioned ivory. The job came out great and he said he had no troubles...
Dcolella
| | | | | Joined: Sep 2003 Posts: 1,820 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 1,820 | I know a woman whose body contains silicone! Oh - it's not natural though! All serious aside, R-M Paint (if they're still around) used to offer a silicone-wax remover in gallon cans to be used on a vehicle before you began the sanding process. It was a product you could soak a clean rag with and wipe it on, then wipe it off. I'm sure other paint brands offer such a product. Joe
"Truckin' Around .......... Since 1937!" My name is Joe and I am addicted to Classic Country Music. I just can't hep myself.Operators are standing by to take your calls! Now cruising in the Passing Lane | | | | | Joined: Apr 2005 Posts: 36 New Guy | | New Guy Joined: Apr 2005 Posts: 36 | before any body work is ever done on any part of a car or truck. wash the whole thing down with dish soap or plain clothes deturgent. make sure the soap doesnt have lanilin in it.(keeps hands soft)
when you use wax remover/ degreases (for paint) always wear nitrile gloves or better, and the paper towls you use. make sure to either use torque or blue shops towls. the paper towls need to be woven NOT glued.
Always clean with a "final clean" less harsh wax/grease remover.before paintting before and after masking right beforepaintting.
check air supply from compressor and air supply to were you are paintting.
And if worse come to worse add a small amount or fish eye additive.
DustyG.
1952 Chevy 1.5 ton 1949 Gmc 2 ton flatbed Dump
| | | | | Joined: Nov 2001 Posts: 275 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 275 | It may be that the silicon did not permeate your paint but that you just moved it around by sanding, etc. without first getting the surface clean. You might try a product call "Poly-cracker. I think you'll find that if you have used Armorall or any similar product in proximity to the area you are trying to paint, you will experience fish eye. Wet coats are especially troublesome. You might solve the problem by putting down multiple, light, dry coats. It took me 3 weeks of putting down light coats every day to solve fish eye on the black painted areas of the dash in my wife's '67 Impala SS--the result of the PO using Armorall on the interior for 15+ years. I thought I'd never get it right!  | | |
