8 members (32Fordpuchoptop, 3B, TUTS 59, Shardean, msmall, carbking, Bill Hanlon, FrankenChevy), 56 guests, and 2 robots.
Topics128,030
Posts1,055,430
Members48,422
#1171181 06/26/2016 4:34 AM
Z
Z Offline
Hi...my 1/2 ton Chevy 1953 truck was converted to 12V by the previous owner and I have a couple of questions.
#1...how can I tell if the headlight switch I have is 12V or 6V ????
#2...if my switch is a 6V one then can I use it on a 12V system ?????
#3...I need to get a new sealed beam on one side and am wondering if the switch I have is 6V, then will the 6V headlight switch work with a 12V sealed beam ???
Thanks in advance........John
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
A switch doesn't care if you run 6 or 12.
Ex Hall Monitor
Ex Hall Monitor
To build a tad on Cletis' answer. It's the current (amps) that decided whether a switch is happy or not. A 6v system actually uses double the current of a 12v system so your switch should live happily every after on 12v.
Z
Z Offline
Can one use "Halogen " headlight bulbs with these switches ????
Ex Hall Monitor
Ex Hall Monitor
Depends on the current that will be passing through the switch. Having said that, I would be surprised if the draw from a pair of headlights would overtax the switch. If someone has info to the contrary they could enlighten us both.
back yard wrench turner
I'm using HID lights with the original switch. No problems so far.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
I run halogens on my '54 and '56 with stock switches.
Z
Z Offline
the reason I ask this question is that one vendor, CLASSIC PARTS.COM, on page 55 of their 1947-1954 catologue states that Halogen bulbs have higher electrical current so that they recommend their harness #52-298 which is hooked directly to the battery to bypass the light switch....the switch is only used to activate "relays" to turn the headlights on. .....Thought`s ???
This is to put more power to the lights and eliminate any loss in the system. It's recommended in any older 12 volt system when up grading headlights.
Wayne
1989 Silverado
Gas Pumper
Gas Pumper
I run Halogens with no problems using the stock setup, however, it is not a bad idea to go to a relay system. The 7 inch sealed beams for 12 volts are Halogen now. You cant even get the old style anymore. I have no plans to go to a relay system on mine. I do not feel any warmth or notice any problems with the wiring or associated parts. 6 volt systems take twice the current as 12 volts so I think the wiring and everything is plenty fine. Your results may vary. If you go to those new fancy LED or Super Halogens, then go to a relay system.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Z
Z Offline
"YOU CANT EVEN GET THE OLD STYLE ANYMORE"
In Jim Carters catalogue on page 69 it states "head light bulb original" do they mean the look of the glass or that is has lower current flow as compared to newer Halogens ?
Gas Pumper
Gas Pumper
I don't know for sure. If you CAN get the old style incandescents, let me know where because NAPA, RockAuto, AutoZone, O'Reilly tells me they are not available and the new 6020 12 volt Sealed Beams are Halogen. They look the same as the old ones. There is no difference in appearance.
Deve
The Think Tank
Big Bolt Forum Moderator
I ran halogens for years in my 59 Suburban (4 headlights when high beams are on) without relays using the stock headlight switch. Current draw from halogens is a tad more because of wattage. If you are worried about it, run a relay with 10 ga wire up close to your headlights, activating it with the headlight switch. That takes most of the draw off the switch and gives you less voltage drop right at the headlights. That means brighter lights, at least in theory and according to everything you read on the interweb!
Mike
Make sure that you have good ground when you run the halogen bulbs.
1958 Chevrolet 3600 NAPCO 4x4 Apache
"Calvin"
