0 members (),
97
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,128 Posts1,056,358 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | Hi...my 1/2 ton Chevy 1953 truck was converted to 12V by the previous owner and I have a couple of questions.
#1...how can I tell if the headlight switch I have is 12V or 6V ????
#2...if my switch is a 6V one then can I use it on a 12V system ?????
#3...I need to get a new sealed beam on one side and am wondering if the switch I have is 6V, then will the 6V headlight switch work with a 12V sealed beam ???
Thanks in advance........John
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
| | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | A switch doesn't care if you run 6 or 12. | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | To build a tad on Cletis' answer. It's the current (amps) that decided whether a switch is happy or not. A 6v system actually uses double the current of a 12v system so your switch should live happily every after on 12v.
| | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | Can one use "Halogen " headlight bulbs with these switches ????
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | Depends on the current that will be passing through the switch. Having said that, I would be surprised if the draw from a pair of headlights would overtax the switch. If someone has info to the contrary they could enlighten us both.
| | | | | Joined: Sep 2010 Posts: 1,708 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,708 | I'm using HID lights with the original switch. No problems so far. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I run halogens on my '54 and '56 with stock switches. | | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | the reason I ask this question is that one vendor, CLASSIC PARTS.COM, on page 55 of their 1947-1954 catologue states that Halogen bulbs have higher electrical current so that they recommend their harness #52-298 which is hooked directly to the battery to bypass the light switch....the switch is only used to activate "relays" to turn the headlights on. .....Thought`s ???
| | | | | Joined: Sep 2010 Posts: 1,708 back yard wrench turner | | back yard wrench turner Joined: Sep 2010 Posts: 1,708 | the reason I ask this question is that one vendor, CLASSIC PARTS.COM, on page 55 of their 1947-1954 catologue states that Halogen bulbs have higher electrical current so that they recommend their harness #52-298 which is hooked directly to the battery to bypass the light switch....the switch is only used to activate "relays" to turn the headlights on. .....Thought`s ??? This is to put more power to the lights and eliminate any loss in the system. It's recommended in any older 12 volt system when up grading headlights. Wayne1938 1-Ton Farm TruckStovebolt Gallery Forums1989 Silverado 1996 Mustang GT convertible When I die, I hope she doesn't sell everything for what I told her I paid for it! | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I run Halogens with no problems using the stock setup, however, it is not a bad idea to go to a relay system. The 7 inch sealed beams for 12 volts are Halogen now. You cant even get the old style anymore. I have no plans to go to a relay system on mine. I do not feel any warmth or notice any problems with the wiring or associated parts. 6 volt systems take twice the current as 12 volts so I think the wiring and everything is plenty fine. Your results may vary. If you go to those new fancy LED or Super Halogens, then go to a relay system. | | | | | Joined: Jan 2016 Posts: 246 Shop Shark | | Shop Shark Joined: Jan 2016 Posts: 246 | "YOU CANT EVEN GET THE OLD STYLE ANYMORE" In Jim Carters catalogue on page 69 it states "head light bulb original" do they mean the look of the glass or that is has lower current flow as compared to newer Halogens ?
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I don't know for sure. If you CAN get the old style incandescents, let me know where because NAPA, RockAuto, AutoZone, O'Reilly tells me they are not available and the new 6020 12 volt Sealed Beams are Halogen. They look the same as the old ones. There is no difference in appearance. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | I ran halogens for years in my 59 Suburban (4 headlights when high beams are on) without relays using the stock headlight switch. Current draw from halogens is a tad more because of wattage. If you are worried about it, run a relay with 10 ga wire up close to your headlights, activating it with the headlight switch. That takes most of the draw off the switch and gives you less voltage drop right at the headlights. That means brighter lights, at least in theory and according to everything you read on the interweb! | | | | | Joined: Feb 2008 Posts: 108 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 108 | Make sure that you have good ground when you run the halogen bulbs. | | |
