0 members (), 146 guests, and 2 robots.
Topics128,162
Posts1,056,939
Members48,458
#1171139 06/25/2016 10:22 PM
Trying to replace spring shackle bolts / pins and probably spring eyelet bushing. Looks like the easiest way will be to cut rivets and remove the whole thing as a unit and then press out shackle pin. Anyone ever done it that way?
Dave
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0462.htm
That's what the manual shows, but I took the advice I found in a previous thread and drove the pins out from the back (there are holes in the frame so that you can place a drift or punch on the backside of the pin and hit it with a hefty hammer). Just make sure you remove the lock bolt first; otherwise, that pin won't go anywhere.
http://chevy.oldcarmanualproject.com/shop/1948_51truck/51ctsm0460.htm
Figure 86 at the top of the page shows the type of shackles you have.
Liquidated my projects
Now looking for a decent '47-'55.1 3100, 3600, or 3800
After researching this a little there is no bushing in that part of the hanger. The bushing is in the spring
this is a link to an original hanger Hanger link
Dave Chapman
The Hollister Road Company
713-937-0387
[email protected]
www.hollisterroad.com
www.thoroco.com
Ended up cutting the rivets and pressing the pins and all 3 bushing out per side. Took a while but wasn't terrible. Thanks for the help.
Dave
