2 members (Ole49GMC, Hush),
74
Mod | | | Forums66 Topics128,169 Posts1,057,102 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Yesterday my son's engine started making noise. Did not want to idle. Stuck on the side of the road I had to go tow bar him to his catering job and back home.
I heard metallic sound for a second then the engine stalled/stopped running. Not seized. No time to check out the engine for he was booked to cater a party for a sailing club.
Now I have yet to go outside this morning to check out the truck. Though talking with my son last night he felt that if his engine needed a rebuild he may just as well as go for a 350 Target Motor.
I told him most likely the original trans will not bolt up to the 350 so he would have to go with a new transmission as well.
So what's involved?
2 bolt main good 4 bolt over kill base target motor 195 hp seems more than adequate Points or early GM electronic ign/pre computer 2 barrel carb
Trans options
Auto: which 4 spd OD any other one's? Manual: ?
All the steps involved in getting the job done?
| | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | SM-420 or 465, or for OD, an NV-4500 for trans.
| | | | | Joined: Mar 2004 Posts: 6,233 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,233 | I'd dropping in a fresh 235 or 261 and be done...you could have him back on the road in one weekend. The 6-cylinder engines are good engines and have given countless millions of miles of service for decades. Swapping in a V8 will have gas and clutch linkage issues to work out as well as radiator and exhaust fitment issues...this all takes time to research and figure out. My .02 cents, Mike B  | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | I got the truck home last night. After posting this morning my other son and I used my chain come along and a lot of chains and pulled the truck into the driveway up to the garage. That took a long time to do.
After putting all the gear away I took the valve cover off and found the No. 6 intake valve pushrod bent, spring no longer had the the valve keepers on and beat up bad, the top of the valve rotator/oil shield was also off of the valve spring and beat up a bit.
Tomorrow I going to take off the head. Most likely will take off the carburetor, then manifolds, to make the head lighter. | | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | I had a similar experience with my 2-ton a couple of years ago. It turned out the pool pump had failed and took out a couple of rod bearings along with the crank journals. I finally located a '53 235 that would bolt right in. I had to have a custom exhaust pipe made because the manifold commotion is at a different angle, but the pip was shot anyway. My recommendation if you change the engine is to pull the sheet metal off the front of the truck (it comes off in one piece with just a few bolts) and you can get right at what you need to and even do a test start with a garden hose supplying cooling before the body parts go back on. Any 6 "54 or older will bolt right in, the newer ones need a water pump adapter to work with the stock radiator position. As mentioned above, a V-8 will take a great deal of engineering to work; there's a reason Chevy reengineered their whole trucks when the V-8 came out. | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Thanks ED I will be keeping my eye open for a 54 or older 235/261.
What was the 1st year for full pressure oil and 1st year for bearing inserts? Jeffrey | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Thanks ED I will be keeping my eye open for a 54 or older 235/261.
What was the 1st year for full pressure oil and 1st year for bearing inserts? Jeffrey Typo error - 1954 or newer 261? The 261 was introduced in 1954. All 235s from 1954 onwards were high pressure engines, with insert rod bearings. The 1953 235 with Powerglide transmission (car only) was the only (and the first) 235 with insert rod bearings (and higher pressure engine lubrication). | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Typo error - 1954 or newer 261? The 261 was introduced in 1954.
The 1953 235 with Powerglide transmission (car only) was the only (and the first) 235 with insert rod bearings (and higher pressure engine lubrication). Thank you. What years do not need the water pump adapter? Jeffrey
| | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | | | | | | Joined: Oct 2013 Posts: 331 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 331 | The water pump adapters are not a big deal - they're readily available on ebay all day long for cheap.
1950 4100 - unrestored and driven weekly for almost no reason at all.
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | My son is leaning to having the original engine rebuilt. Gentleman here will put in all new valve seats, valve guides, so it can run unleaded, convert from Babbitt to Inserts, new pistons, timing chain and gears, camshaft bushings. In short a thorough job. Jeffrey | | | | | Joined: Dec 2012 Posts: 201 Shop Shark | | Shop Shark Joined: Dec 2012 Posts: 201 | In the long run, not a bad idea. I would do the same if I could swing it. You can often pick up a running engine for $4-500 to put in and get the truck back on the road until the original is ready to go back in. I know how badly downtime can hurt a business. | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | I believe 1954 is full oil and has the water pump in the right place. | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Bring this thread up to date.
Tuesday I brought home a 1954 235 that was originally in a 3800. We are getting that engine rebuilt. 19 more HP, less work because the engine does not need to be worked to replace the Babbitt bearings with inserts.
Hope that there are no major issues hidden preventing the 54 engine from being rebuilt.
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Hope that there are major issues hidden preventing the 54 engine from being rebuilt. I certainly hope you inadvertently forgot the word "not" in the above sentence...unless you are a glutton for punishment. The 1954 year engine is the best one for Deco era trucks. I hope it is rebuildable. The old style valve cover can be bolted to the newer engine making it look almost perfectly original. | | |
