5 members (bnauman, Oswald, 3B, dt235sd, Bill Hanlon), 84 guests, and 3 robots.
Topics128,175
Posts1,057,115
Members48,463
I found what I believe is a "36" 1.5 ton Chevy truck in a grove of trees on an old farmstead. Only things missing are the radiator and the box. Engine, tranny and rear end are all complete and intact. Badge is on complete grill. One badge on one hood, missing on the other. Doors are sitting on the back of the truck. Complete but rusted out on bottoms. Speedometer and other 2 gauges are in dash in decent shape. 93K miles on odometer. Speedo goes to 100 mph. Frame and springs are there for the seat still in truck.Front fenders complete with a couple of small dents. Headlights are on the truck with original brackets. One complete the other has the glass lens broken. Cab looks complete to me with crank out windshield. (Crank Knob intact on dash.) No front glass. What should a guy give for a cream puff like this? Any and all help will be much appreciated. Hell, I might sell my dirt track modified race car and build this bad boy!
"Get busy livin' or get busy dyin"
Welcome,
Try this Tech Tip,
http://www.stovebolt.com/techtips/truckworth.html
Better question is what is it worth to you, having seen it what would you be comfortable giving for the pleasure of taking it home?
Big Bolt Forum Moderator
welcome to the site! One thing to note, while the big bolts are cool, they are generally more expensive to build, run, and maintain and worth less than a pickup. That said, I have 2 2-tons at the moment! LOL.
Mike
If nothing else I will put it in the front yard and build a huge flower box on the back for the wife. Then letter it by hand like an old delivery truck. I can't get hurt at $575 can I? Hell, I guess it's worth that to make the wife happy or mad. I don't know which she will be when I drag it home!
Crusing in the Passing Lane
'36's are pretty rare, so not many parts resources for tin, running gear more readily available, does it have a flathead engine? If so, might be Olds or Pontiac.
How badly rusted are the wheels?
Depends on what you want to do with it? Engine compartment very small for later engine. Mech. Brakes, I presume-parts?
I don't think I would give more than $500., not having seen it.
Ed
I'm with Ed on this. That would be a fair price around these parts. Expect to have north of $50,000 in it when you are done and it would bring about $30,000 at Barrett Jackson.
Wheels look to be in good shape. The tires as you can imagine not so much. It does not have a flat head. Straight 6 complete less the dist. cap and wires. The metal border is there for the box that I would guess had a wood bed. Isn't the grill with Chevy badge worth $300? Gauges? Badge off of the hood? Wheels, Glove box door, Choke knob and what ever the other pull knob is. Bell housing. tranny, drive shaft.Frame is solid, not near the ground. I guess the wife is getting a $575 planter. I told the man I would take it I I am a man of my word. Thanks everyone!
Send us a px, give us a idea of what you want in the end, we'll give some ideas.
My input would be, if you don't want to keep it exactly original, but a driver, would be to put later axles, hydraulic brakes, steering under it. If not a flathead in it, what is it?
GMC engine SN's start with displacement, i.e. 228xxxx, etc. if an overhead valve. Stamped number on pad behind starter on starboard side, port side on big engines.
Ed
Ed, Chevrolet never made a flat head engine...
Jimmy, the 1936 trucks could be mechanical or hydraulic brakes. The engine is a one year block, the hood sides will have horizontal lovers. There were two cabs made in 1936, a High cab with three door hinges and a Low cab with two hinges.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Doors have 2 hinges, Hood sides have 2 louvers, top one longer than other, chrome chevy badge above top louver just about centered if not centered. Mechanical brakes. If I can figure out how to upload pics from my phone I will. Thanks everyone. "Get Busy Livin' or Get Busy Dyin"
Can I upload pics into this thread?
Follow the photo instructions in the left margin of the forums. "Image Posting Policy" is for everything photo related.
Authorized Pest
Authorized Pest
P Online: Content
You can upload a link to photos.
~ Peggy M
1949 Chevrolet 3804
"Success comes in 'cans' ..."
Mike, sorry I missed it was a Chevy instead of GMC.
Ed
What bolt pattern is the front wheels. Need to get tires on it to move it. Rim size on front? If needed I will unbolt the front wheels and have tires put on just to tow it.
Can you please share some pictures so we can guess more accurately?
Grigg
•1952 Chevrolet 3800 pickup
---All pictures---
Welcome to the stovebolt world.
If this new find has been aging in the field for a long time, the chances of you getting the lug nuts off without breaking something is remote. They will most likely need some heat, penetrant, time, and a stout impact wrench. I would recommend that you just skid it up on a low trailer or a rollback and begin the disassembly where there are tools available.
Good luck, it sounds like a cool project, and I hope you figure out the image posting so we can see your "new" truck.
Paul
Lots more pictures
Sometimes water/ice or oil/grease under a stuck wheel will allow movement.
Ed
I can't figure out how to upload photos from my phone so, go to Facebook/jim blazina to see many pics
Moderator
Moderator
2 Offline
Here is the facebook link.
https://www.facebook.com/jim.blazina
That's going to be a real project.
"Flower bed for the wife". Good one.
Don
"The Flag Pole"
1946 2-Ton grain truck
1946 3/4-ton pickup,
1953 1-ton pickup
1957 1-ton flatbed dually,
1954 Pontiac Straight Eight
I
I Offline
Good rat rod material there
