0 members (),
132
Mod | | | Forums66 Topics128,290 Posts1,058,566 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I'm looking for some details and differences in the various 48-54 GMC maintenance manuals, particularly the wiring diagrams, if any difference. I have what I thought was the right manual for my 51, it's a reprint (was listed as an original when I bought it) and "covers" 47-54 and models 100-400. This is not where I bought it but it is the same manual http://www.faxonautoliterature.com/...00-Repair-Shop-Manual-Reprint-P9815.aspxThey describe the manual: This is the book GMC originally used to repair 1953 and 1954 models. It can be helpful for 1947-1952 models also In my searching I see that GMC did offer a manual to cover the 1951/52 model trucks size 100-350, this is the exact manual that covers my particular GMC. Here is a reprint, originals can also be found, they have "X-5111" in the upper right corner of the cover. http://www.faxonautoliterature.com/...k-Repair-Shop-Manual-Reprint-P25248.aspxI'll probably find and buy one of these originals in time. Until then does anyone have this GMC 1951-1952 only manual and can you show me the wiring diagrams so I can compare to the diagrams in the 1953-1954 manual (the manual now sold as 47-54)? Thanks, Grigg | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | There are no GMC Maintenance (Shop) Manuals at either of the links above. If I am incorrect, please post a link to a specific manual. As Grigg posted, the "reproduction" GMC manuals are often multi-year, and the 1954/55 (Z-series) GMC wiring might be a little different, due to different dash. However, the type of gauges did not change, just the style and location of gauges. The GMC and Chevrolet Truck gauges were not at all similar in 1954/1955st trucks. There is only a 55-59 GMC small truck Maintenance Manual at Keith Hardy's OLD ONLINE CHEVY MANUALS (no separate GMC wiring diagrams). http://chevy.oldcarmanualproject.com/gmc/5559mm/index.html | | | | | Joined: Jan 2016 Posts: 1 New Guy | | New Guy Joined: Jan 2016 Posts: 1 | How do you find the bold pattern of a 1954 chev 3/4 ton with 16 in wheels?
I have a 1954 3/4 on factory flatbed with a 4 speed with granny low. Cab needs some body work. It's just a shell. no glass. motor, trans and rear are all there and working. Recently overhauled and all new brakes. It is all original. It has the gauges and I bought a Painless Wire harness for it Got good gas tank behind seat. No original seat. I got 2 black leather power seats that will work well. First time doing something like this. I think I took on too much with this project.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Daniel, You should post a new/different question as a New Topic (with a new title). If GMC 3/4 ton was the same as 1954 Chevrolet, look at the various 3600 wheel specs. How many bolt holes on your wheels? 8 bolts in a 6.5" circle? 6.50x16" with 5.50" rim width and 4 9/16" rear offset? | | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | I think I found my manual on e-bay. I think. It was like yours. Went through several year models. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | How do you find the bold pattern of a 1954 chev 3/4 ton with 16 in wheels? http://chevy.oldcarmanualproject.com/chevyresto/54159.htmIn the future, you might want to post/start a new/separate topic, when you have a question not related to the original post in a thread. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Back to manuals,
If anyone has one of the earlier GMC manuals with X-5111 in the corner of the cover I'd like to see pictures/scans of the wiring diagrams.
I'm not really expecting any significant differences compared to the 53/54 wiring diagrams but I'd like to look and see just for my own curiosity.
Thanks, Grigg | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I just ordered some original/used manuals. A small 1951 GMC operators manual that should have a wiring diagram in it though not sure how detailed, hopefully fully. Also a 1949 GMC maintenance manual, I can then at least compare the 49 diagram to the reprinted 53/54 diagram, and if no difference then likely 51 is also no difference.
In time I'll find a 51 maintenance manual at a better price. I do like old books and manuals... | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | I have never seen an operators manual with a wiring diagram. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Me either, but the few pictures of it on eBay showed one, 1951 GMC... I'll know more when it shows up. PIC. 1 PIC. 2 Grigg
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I've collected, scanned, cropped and edited for clarity, and noted the printing date on the various GMC wiring diagrams. They are pretty large clear images and should print well. They can all be found in this album https://goo.gl/photos/H26qPfBHb7eS15698Here is the 1951 GMC diagram from the owners manual. https://goo.gl/photos/UvtdEAKaUC6EATES9To answer the original question: The 1951 conventional truck wiring diagram is the same info as on the 1953 diagram. The 1953 diagram however includes more info for the optional hydromatic, optional electric wipers, and optional electric two speed axle. The 1951 and 1953 COE wiring diagrams I believe are exactly the same, no changes/additions. The 1949 diagram is drawn in a different configuration and hard to compare, though it obviously functions about the same I suspect there might be a few connection details/differences. The wire color code is a legend on a separate page. I believe there are some differences in the color code for the same wire function between the 1949 and 1953 diagrams. Grigg | | |
