| | | Forums66 Topics128,081 Posts1,055,959 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2014 Posts: 82 Shop Shark | | Shop Shark Joined: Dec 2014 Posts: 82 | hi.
out of nowhere the speedometer needle now bounces around 20 mph plus and 20mph minus of what the real speed is.
so, if I am going around 40mph, the speedometer bounces between 20mph and 60mph (more or less)
and the odometer no longer advances.
where should I start to try and find out what is wrong - since this worked fine for months.
thanks in advance
| | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | You have two choices. 1) Teach yourself how to disassemble, clean and repair what you have. 2) Buy a new one. I have done both in the past. I prefer #2. Carl
| | | | | Joined: Feb 2008 Posts: 1,122 'Bolter | | 'Bolter Joined: Feb 2008 Posts: 1,122 | Learning how to repair one can be done. Believe me if I can do it anyone can.
Just take your time, read, re-read the Tech Tip here in the Stovebolt, and if need be ask questions here. If you get, most likely when, frustrated...walk away for bit. I know I had to. Fat, stiff fingers and failing eyesight and slow wit were only part of the challenge with the tiny pieces.
Good luck! | | | | | Joined: Apr 2004 Posts: 5,074 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,074 |
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | does it matter if it is a 55-57, I think the poster has a 55 but I am not sure and it may not make a difference??
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Jan 2016 Posts: 631 'Bolter | | 'Bolter Joined: Jan 2016 Posts: 631 | What is the condition of the speedo cable. Even new replacement can benefit from grease. The new one I purchase was dry as a bone. Dry, kinked, rusted and bent cable can cause jumping needle.
The odometer not advancing is not the cable.
| | | | | Joined: Jul 2016 Posts: 1 Moderated | | Moderated Joined: Jul 2016 Posts: 1 | Hi, I'm new to postings. Don't know where to post this looking for a 1965 chev c 10 step side short box ( roll up cover for the box) . Can anyone help. Thanks Ron | | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | you might check into the welcome forum first and then go to the parts wanted forum.. plenty of help...check in and then go looking
welcome from TX Fred Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | |
