0 members (), 254 guests, and 2 robots.
Topics128,094
Posts1,056,066
Members48,433
hi.
out of nowhere the speedometer needle now bounces around 20 mph plus and 20mph minus of what the real speed is.
so, if I am going around 40mph, the speedometer bounces between 20mph and 60mph (more or less)
and the odometer no longer advances.
where should I start to try and find out what is wrong - since this worked fine for months.
thanks in advance
You have two choices.
1) Teach yourself how to disassemble, clean and repair what you have.
2) Buy a new one.
I have done both in the past. I prefer #2.
Carl
Learning how to repair one can be done. Believe me if I can do it anyone can.
Just take your time, read, re-read the Tech Tip here in the Stovebolt, and if need be ask questions here. If you get, most likely when, frustrated...walk away for bit. I know I had to. Fat, stiff fingers and failing eyesight and slow wit were only part of the challenge with the tiny pieces.
Good luck!
Authorized Pest
Authorized Pest
~ Peggy M
1949 Chevrolet 3804
does it matter if it is a 55-57, I think the poster has a 55 but I am not sure and it may not make a difference??
Redryder pix
My Hotrod
What is the condition of the speedo cable. Even new replacement can benefit from grease. The new one I purchase was dry as a bone.
Dry, kinked, rusted and bent cable can cause jumping needle.
The odometer not advancing is not the cable.
Moderated
Moderated
Hi, I'm new to postings. Don't know where to post this looking for a 1965 chev
c 10 step side short box ( roll up cover for the box) .
Can anyone help. Thanks
Ron
you might check into the welcome forum first and then
go to the parts wanted forum.. plenty of help...check in and then go looking
welcome from TX
Fred
Redryder pix
My Hotrod
Moderated by  ndkid275, Phak1
