3 members (Rich'sToys, dt235sd, BC59), 45 guests, and 4 robots.
Topics128,179
Posts1,057,157
Members48,465
#1170635 06/22/2016 1:48 AM
the grommet to steel tube is not a real tight fit like others have mentioned in other articles should I use a sealer for the tube and a sealer to the body of the cab?
I would rather be late 10 minutes in this life than 10 minutes early for the next
The reason my lady and I have been together so long is because of the kids. Neither one of us wanted sole custody
Rubber shrinks with age so get a new grommet. Also check if filler neck is centered into the hole. The tank could of shifted adding to the gap. Jeffrey
Hi 32vld, in fact it is a new grommet out of the package
Ex Hall Monitor
Ex Hall Monitor
Is the one you bought from Steele? If not buy one from them. See if it fits better. Rubber repop parts are not created equal. For that point a LOT of repop parts are substandard, rubber or otherwise.
