2 members (Gdads51, tclederman),
219
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,085 Posts1,056,091 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2005 Posts: 77 'Bolter | | 'Bolter Joined: Jul 2005 Posts: 77 | I need help freinds I have a 1952 Chevy Truck that needs some minor frame repair. The guy at the body shop asked me to get him the specs of the frame. He said that the only way to get the frame right was to get the origianl specs. Does any one know where I can get these specs from? John
John Kinser
| | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | That info is in the 1947-1954 Chevy Truck Factory Assembly Manual (sect. 2 sheet 2.00). Most of the vendors have this manual... Chevy Duty, Jim Carter and etc. | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | The Factory Assembly Manual seems to use drawings from '54/'55-1st trucks. The '54/55-1st frames had changes in a few places, in comparison to earlier Advance Design frames.
Maybe someone who has frame information for 1952 and 1954 can comment on whether the frame changes that took place in '54 are significant (with respect to using the '54 measurements for '52 repairs). I do not know enough about the differences to answer this.
Tim | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | The shop manual gives the six diagonal dimensions from the spring mounting points, along with several width measurements. The restoration pack gives the frame thickness and the channel dimensions. If you want me to scan them for you, send me an Email. | | |
