3 members (Naturalthud, Southerntruck, Peggy M), 285 guests, and 0 robots.
Topics128,080
Posts1,056,062
Members48,433
#117068 07/25/2005 9:45 PM
I need help freinds
I have a 1952 Chevy Truck that needs some minor frame repair. The guy at the body shop asked me to get him the specs of the frame. He said that the only way to get the frame right was to get the origianl specs. Does any one know where I can get these specs from?
John Kinser
#117069 07/25/2005 10:45 PM
That info is in the 1947-1954 Chevy Truck Factory Assembly Manual (sect. 2 sheet 2.00). Most of the vendors have this manual... Chevy Duty, Jim Carter and etc.
#117070 07/26/2005 12:20 AM
The Factory Assembly Manual seems to use drawings from '54/'55-1st trucks. The '54/55-1st frames had changes in a few places, in comparison to earlier Advance Design frames.
Maybe someone who has frame information for 1952 and 1954 can comment on whether the frame changes that took place in '54 are significant (with respect to using the '54 measurements for '52 repairs). I do not know enough about the differences to answer this.
Tim
#117071 07/26/2005 12:35 AM
The shop manual gives the six diagonal dimensions from the spring mounting points, along with several width measurements. The restoration pack gives the frame thickness and the channel dimensions. If you want me to scan them for you, send me an Email.
1951 1 Ton Completed
