3 members (Lightholder's Dad, Charles in CA, Philipj), 63 guests, and 2 robots.
Topics128,154
Posts1,056,838
Members48,456
Z
Z Offline
I forgot which way the star wheel should be moved to back off on the brakes.
Which way does spoon handle go when backing off the brakes ?.......the end where you hold the spoon ?
Does the Rear of the spoon handle goes up toward the bed or down toward the floor in backing off the brake shoes ????
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
Riding in the Passing Lane
To back off the brakes move the handle down.
1972 Chevy c10 Cheyenne Super
Crusing in the Passing Lane
I always remember you bang your knuckles on the spring when tightening.
Ed
Gas Pumper
Gas Pumper
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Thanks Deve, I made copies of your drawing to put in my car log book as I to, never can remember.
ODSS President
ODSS President
Yes, Righty-Tighty, Lefty-Loosey, real confusing (to me) when I'm underneath and on a creeper. Seems like I have to re-learn the procedure every time I do it.
Thanks Deve!
~ Cosmo
1949 Chevy Half Ton
Nice, Deve
Z
Z Offline
thanks...I always forget...I will print out the diagram.
That tech tip should apply to TF and later as well, right?
1959 3100 Apache Fleetside
Gas Pumper
Gas Pumper
yes.
Deve
The Think Tank
How about Huck brakes with two adjusting wheels on each cylinder?
Facing the end of the wheel cylinder you turn the adjuster's in a clockwise direction. Jeffrey
Up to about 63 when they changed to self adjusters. They turn the opposite direction & you need to pull the adj. lever back to back them off.
my rears have a front and rear star,turn opposite directions to tighten ????
just-a-hacker
'49 3100 before '99
Your 49 has Huck brakes. You adjust them like VDL says.
