9 members (JoergK., Bill Hanlon, J Lucas, Chip O, dt235sd, Gdads51, Hotrod Lincoln, 2 invisible),
75
0
Mod | | | Forums66 Topics128,205 Posts1,057,427 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 35 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 35 | May sound dumb, but I removed the drive shaft from the torque tube to replace the forward two shaft bushings (now complete) and I've cleaned the two bearing at the rear of the drive shaft (both the front and rear bearings that fit into the differential housing).
Do I pack these two bearings with grease, or are they lubricated with the differential oil???? | | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | The bearings at the rear of the torque tube are lubed with the same oil as the differential. I use a light grease to protect them at first, splash will lube them right soon after the diff starts to spin. The bushing at the front is lubed with transmission oil..and yes, I lube that bushing with a light grease as well. It takes a bit of time to fill the "ball" and have the splash start working. Assembly grease seems to do the trick. Never let any thing run dry. Ever. Transmission gear oil will not stay on the bushing long enough(my opinion) so a bit of grease keeps my conscience happy.
Steve H
| | | | | Joined: Jun 2014 Posts: 35 'Bolter | | 'Bolter Joined: Jun 2014 Posts: 35 | Steve thanks what kind of grease/ light lube should I use?? Should I use wheel bearing grease, or something else to keep things lubricated until first use??? | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | Hi 35truck , , get into this http://old-carburetors.com/1935-Chevy.htmps, yes any chassis grease will do as an assembly lube . .
| | | | | Joined: Jun 2012 Posts: 1,749 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,749 | Any grease would do. The heavy stuff is hard to work with and assembly grease is easy. The point is to use what won't drain off. I have looked around my "shop/shed" and found..wheel bearing(works), Light chassis(works) and, some white lithium(assembly lube in a tube, it worked too).
Steve H
